Group: DynoMotion Message: 1033 From: andyshillabeer Date: 4/9/2011
Subject: URGENT HELP NEEDED - Kflop Stopped connecting to computer
Hi folks,
I am in a crunch. I have a kflop board which is running a motion control system. It has been working fine connected to my netbook (which runs the motion control software) by USB. Power to the Kflop is from the USB.
The other day I ran a test and everything was working fine. The only thing out of the oridnary was that the netbook battery ran out mid process and shut down. That is the only things that has changed otherwise the set up has worked fine for months.
I just went to use the system again and now the kflop will not connect or show up on the netbook.
Now when the USB is connected to the netbookthe two status LED's blink alternately a few times and then only one remains lit. The one which remains lit is marked D1 and is the one furthest in from the edge of the board.
I have checked all the connectors and inputs to the board and all seem fine. As expected as nothing happened to change anything.
Any help would be greatly appreciated. I have a job with this set up on Sunday and then for the next two weeks so figuring it out is quite urgent. Unfortunately the guys who provided and programmed the kflop for me is out of town and I can't get hold of him.
Here's hoping for an easy solution.
Best
Andy
Group: DynoMotion Message: 1034 From: Tom Kerekes Date: 4/9/2011
Subject: Re: URGENT HELP NEEDED - Kflop Stopped connecting to computer
Hi Andy,
I'm afraid you will probably need to get a hold of the person who programmed the board.  The flashing lights happen after the primary bootup before KFLOP jumps into the main firmware and User code.  It sounds like somehow the main firmware and User programs somehow are corrupted.  There is a way using our KMotion.exe executive program to perform a "Flash Recovery" to restore the main firmware.  If you do this the board will probably then connect to the PC but if you don't have the required User Programs your system will still not function.  You can try this without loosing anything by performing the Recovery but NOT Flashing anything.  The boot Recovery loads a version of firmware from the PC into KFLOP's RAM and does not alter any Flash memory, so if you cycle power and reboot from Flash you will be back to the same state you are now, but you will know the Laptop and KFLOP hardware is good and can communicate.  Normally after the recovery loads a version into RAM and is running and communicating with the PC, the next step would be to Flash a Version or User Programs to the board, but as I said in this case I would not do this before talking to the person who programmed the board.  You might also try removing all connectors from the KFLOP board except the USB to see if you get the same results to eliminate the odd chance that something in the hardware is causing the communication problem.
Sorry for not having a simple solution.  Good Luck.
Group: DynoMotion Message: 1035 From: andyshillabeer Date: 4/9/2011
Thanks for the info. That is kind of what I suspected. Forgive my ignorance but what is the step by step process to try the recovery but NOT flash using the KMotion.exe if the board isn't talking via USB. I tried running the kmotion software to check version etc and it said no board connected?
Cheers
Andy
> Hi Andy,
> From: andyshillabeer <acsfilms@...>
> Sent: Sat, April 9, 2011 5:51:00 PM
> Subject: [DynoMotion] URGENT HELP NEEDED - Kflop Stopped connecting to computer
> Hi folks,
> for months.
> up on the netbook.
> Best
> Andy
Group: DynoMotion Message: 1036 From: andyshillabeer Date: 4/9/2011
I tried with all connectors unplugged except USB and no difference.
Just trying to find if I have the user program for flashing on my pc already as back up.
Andy
> Cheers
> Andy
> > Hi Andy,
> > From: andyshillabeer <acsfilms@>
> > Hi folks,
> > for months.
> > up on the netbook.
> > Best
> > Andy
Group: DynoMotion Message: 1037 From: Tom Kerekes Date: 4/9/2011
With power to KFLOP switched off go to the KMotion Config Flash Screen and push "Recovery".
Push OK after the warning.
Select the Firmware .out file you wish loaded to RAM (use the default shown).
Follow the prompts.
Group: DynoMotion Message: 1038 From: Andy Shillabeer Date: 4/9/2011
Hi there Tom,
I just tried that and after it goes through the upload process (green bar shows full progress it gives a an error "timeout establishing bootloader connection"........... any thoughts?
Andy
Andy Shillabeer
Cameraman
www.lostworldfilms.com
(for demo reel, newly uploaded clips - user: producer / pwd: guest)
www.spider-cine.com
(for the latest on the new BLACK WIDOW cable dolly system)
+44 (0) 7767 233286 (uk)
+1 408 656 6010 (usa)
skypename: andyshillabeer
visit www.treestorymovie.com for details of one of our current projects
visit www.iawf.org.uk for up-to-date info and chat on the world of wildlife film-making
-----Original Message-----
Sent: Sat, Apr 9, 2011 7:03 pm
Subject: Re: [DynoMotion] Re: URGENT HELP NEEDED - Kflop Stopped connecting to computer
Follow the prompts.
Group: DynoMotion Message: 1039 From: Tom Kerekes Date: 4/9/2011
Hi Andy,
Hmm not what I expected.  You did apply power as directed correct?  The green bar doesn't actually indicate any uploading.  That is just the time allowed for you to apply power and for the USB device to go active.  If the green bar goes finishes it means either you never applied power or the USB device never connected for some reason.  WIth KFLOP connected what shows up in Windows Device Manager under USB Devices?    Have you tried a different computer?  Do you know if the User Program turns off one of the LEDs when running normally?  If your PC is ok that would unfortunately indicate that the KFLOP is somehow unrecoverable.
Rergards
Group: DynoMotion Message: 1040 From: Andy Shillabeer Date: 4/9/2011
Luckily I managed to get hold of the programer and I believe one of the LEDS may turn off after boot. On his suggestion I tried the Kflop with external power, not USb and still no connection with computer. I also tried connecting to my laptop (win 7 64 bit) but nothing happens there either. No attempt for USB to connect. Also tried different USB cable with no effect.
So I guess I can only assume that something on the board is fried. And the only possible event that seems like it could have caused that is the controlling netbook's power running out, which in itself is alarming as my use of the kflop board is in a system used outdoors a lot where the likelihood of battery failure is always present despite our best efforts to avoid it.
Best
Andy
Andy Shillabeer
Cameraman
www.spider-cine.com
Sent: Sat, Apr 9, 2011 8:18 pm
Hi Andy,
Rergards
